I have this (run) capacitor with 4 terminals for a sewing machine motor. I have fixed some minor issues but now I realize I don't know how the wiring was before. I don't find an explanation for the scheme on the back of it anywhere so I post the image here Capacitor back
Two terminals should connect the motor and the others two the pedal.
A front image, too, in case it helps: Capacitor front
I have not found anything about this model/type anywhere
This is not a capacitor but a mains input filter/Power line filter (which, as shown on the little schematic that is printed on top of it contains two capacitors and a common-mode choke) It's placed in series with the input - one side has the power line, other side has the device being powerd. If you are still not sure, I suggest googleing the topic.
  • \$\begingroup\$ I see. Red and yellow to input and black wires to coils. Thanks for the explanation and correction \$\endgroup\$ – ali May 14 '17 at 9:36
  • \$\begingroup\$ I guess the motor can run without it, too. It blew up (old, I guess) and cannot find another one \$\endgroup\$ – ali May 23 '17 at 7:06
