Can anyone help me to understand why this sentence below (which I had find it in a paper) is correct?
Designers must address the tradeoff between low-noise and low-power designs of the amplifier.For an ideal thermal-noise-limited amplifier with a constant bandwidth and supply voltage, the power of the amplifier scales as \$1/(vn^2)\$ where \$vn\$ is the input-referred noise of the amplifier.
But I had read in a lot of books that refer that the thermal noise given by this expression \$P = K \cdot T \cdot \Delta f= \dfrac{vn^2}{4 \cdot R}\$ so power and \$vn\$ are proportional. So which statement is correct?
