I am looking at this current limiting circuit on Wikipedia, which says that
The optional component R2 protects Q2 in the event of a short-circuited load.
Can someone explain why Q2 needs protection in this condition?
My understanding is that when Rload is shorted, the base of Q2 will see a voltage of Vcc, minus Vce of Q1 (because Q1 is in saturation, due to R1). Assuming that's above Vbe (of Q2), current will flow, but immediately cause Q2 to sink current from the base of Q1 - cutting it off.
Is the purpose of R2 to protect against this initial surge then?
Does R2 not affect the operation of the circuit? (As it forms a voltage divider with the base of Q2 - where the voltage is sensed) Or is it assumed that Q2 Ib is so small, that the voltage drop is negligible?
