I've found this MOSFET-shaped component inside a Dell laptop power supply (I've lost the case so I can't tell you any details, sorry):
The problem is that I can't find any datasheet for it anywhere.
I will try and describe it in terms of the lines of text on the front:
  • Line 1: C6312
  • Line 2: A picture of two diodes facing each other.
  • Line 3: 004
For the most part, it looks exactly like a MOSFET, metal back etc, and it is also mounted on a heat sink if that is useful.
Through some research I think I've narrowed it down to a Schottky barrier rectifier stack based on the symbol of the two diodes facing each other.
This isn't super serious or urgent, but I'm really interested to know what it is!
    \$\begingroup\$ A photo would help. If not, then specify the actual package (e.g. TO220) because MOSFETs come in quite a few different packages. \$\endgroup\$ – Jack B Aug 5 '17 at 11:38
  • \$\begingroup\$ I just added a photo which should help. \$\endgroup\$ – Scrapper Aug 5 '17 at 11:46
  • \$\begingroup\$ That doesn't seem to be part of the original design, but a hack or a bodge added as an afterthought. Are you sure the power supply had not been serviced/hacked before? \$\endgroup\$ – Lorenzo Donati Aug 5 '17 at 12:05
  • \$\begingroup\$ I'm 100% sure it's never been opened before. I got it off my dad who was throwing it away and he's a super safety freak. He was the only owner and would never open it, let along modify it. On the other half of the PCB, it was also heatshrinked along with a few other wires, so it had to have been part of the original design. Plus it has designated holes to solder the wires to. \$\endgroup\$ – Scrapper Aug 5 '17 at 12:17
    \$\begingroup\$ Probably it is more likely some form of dual common-cathode rectifier diode (similar to this). \$\endgroup\$ – Tom Carpenter Aug 5 '17 at 12:22
9
I think you are on the right track, but the 12 in the part number is a red herring, IMO. Probably a date-code.
After a bit of detective work, the most likely candidate I found was this ESAC63-004 common cathode Schottky diode array:
From what you say, it could be the rectifier of the output of the power supply, as can be seen in an image of a DELL power supply found here (emphasis on the image is mine):
EDIT
Another datasheet for the same part can be definitive (yellow highlighting is mine):
I believe it is a Silicon Diode, you might want to check this datasheet
http://pdf1.alldatasheet.com/datasheet-pdf/view/218943/FUJI/ESAC63-004R.html
