So i have a circuit where R1 = 5 W, R2 = 2 Ω, L = 1 H, C = 1/6 F ja E = 2 V. And i need to figure out what is iL when t=0.5s with laplace transform.
Switch opens when t=0
When t<0 i got iL(0)=1A and Uc(0)=0 for initial values.
When t>0 circuit will look like enter image description here
And now i got for KVL i got
$$ E-U_L-U_R-U_C=0 $$ $$ E-Li_L'-\frac{i_L}{P}-\int\frac{i_L}{C}=0 $$ And now in need to do laplace transform. $$ E-L(sI_L-i_L(0))-\frac{I_L}{P}- \frac{1}{C}*(\frac{1}{s}*I_L)=0$$ But now i got stuck here. Thanks in advance.
  • \$\begingroup\$ The capacitor has 2V at t=0, the same voltage as over R2. \$\endgroup\$
    – user136077
    Commented Nov 6, 2017 at 11:40
Assuming R1=5Ω ,
Initially, \$V_C\ + V_{R_1} = V_{R_2}\$. Since no current flows through C for \$t(0^-)\$ , \$i_{R_2}=1A\$. So, \$V_{R_2}=V_C=2V\$.
For \$t>0\$,
$$E=L\frac{di}{dt} + i\cdot R_1 + \frac{1}{C}\int i dt + V_C(0)$$
Taking Laplace Transform,
$$\frac{E}{s} = L(sI(s)-I_L(0)) + I(s) \cdot R_1 + \frac{1}{Cs}I(s) + \frac{V_C(0)}{s}$$
Here \$I_L(0) = 1A, V_C(0) = 2V\$
Rearranging,
$$\frac{E+LsI_L(0)-V_C(0)}{Ls^2 + s R_1 + \frac{1}{C} } = I(s)$$
Substitute the values and resolve into partial fractions and then take Inverse Transform to get the value of the current.
Edit:
The Laplace Inverse of 1/7 is 1/7δ(t), which is a function that takes the value 0 for all \$t\neq 0\$.
  • \$\begingroup\$ Now i got that $$ I(s)=\frac{s}{7s+6} $$ ,and then for partial fractions i got $$ 1/7-\frac{6}{49s+42}$$ and now for inverse transform i have $$\frac{-6}{49}*e^{-(6t/7)}+\frac{1}{7}$$, but now when i put that t=0.5 i got I=-0.15 wich is wrong, do you know what went wrong? \$\endgroup\$
    – J.Doe
    Commented Nov 6, 2017 at 16:03
