I am trying search something which I can use to convert 220V-DC to about 30-50V DC. I don't want it to be a transformer. I found some voltage regulators providing required output but not having the required input, so all useless, but there may be some available which escaped me. You can also suggest something, which I can make at home but not too advanced for a Senior High School student. Thanks.
Edit (Thanks to @Transistor, @Asmyldof) I am trying to make a air cleaner, so trying to power an electric motor having the given range requirement, ie, 30-50V DC. I am converting the 220v AC mains supply to 220v DC(slightly lower) using 'bridge rectifier', which I had already made and tested. I will also use 'filter capacitor' in the circuit (parallel) before the regulator.
