Generally, currents we want to know the effect of the current. For example, how much power or heating does it provide. The standard method for doing this is to calculate or measure the true RMS (root mean square) of the current waveform. If you like, the resultant value gives you the equivalent DC current that would have the same effect as stated in your definition.
Figure 1. A strange AC waveform.
A simple example may help. In Figure 1 we have an AC waveform whose geometric average or integral will be zero. Clearly the power delivered is non-zero so let's calculate the effective current.
- Power is proportional to \$ I^2 \$.
- For the first second power is proportional to \$ 10^2 = 100 \$.
- For the second second(!) power is proportional to \$ 5^2 = 25 \$.
- For the third second power is proportional to \$ 0^2 = 0 \$.
That's the squared part of RMS done. Now get the mean.
- \$ Mean \; of \; squares = \frac {sum\;of\;squares}{periods} = \frac {100 + 25 + 0}{3} = \frac {125}{3} = 42 \$.
Now get the root.
- \$ RMS = \sqrt {Mean \; of \; squares} = \sqrt {42} = 6.5 \$. So the effective current is 6.5 A.
For the negative half-cycle the result will be the same due to the squaring.
Note that if we just calculated the "average" current for one half-cycle (the the positive one, for example) we would have got \$ I_{AVG} = \frac {10 + 5 + 0}{3} = 5 \; A \$. The RMS value is much higher because the \$ 10^2 \$ term has a large effect.
This waveform with a 10 A peak current would heat a resistor by the same amount a 6.5 A steady DC current would.
For a sinewave the RMS value is \$ \frac {1}{\sqrt 2} V_{peak}\$.
