I had made an NE555 timer IC based delay circuit (monostable mode) which keeps output HIGH for 10 seconds when trigger pin is connected to ground momentarily. But what I want is if I ground trigger pin again (momentarily) within the ten seconds, it restart the ten-second timer i.e. start timer again from that moment and keep output pin HIGH for another ten seconds. Any way to do that?
Below is my circuit Diagram.
Update: actually i am trying to replace the Arduino in my motion sensing relay circuit. Arduino is programmed in such a way that if motion is detected it turns relay ON immediately and if motion is not there then turns relay OFF after 1 minute. Also if there is any motion detected within that minute then the timer restarts. I think using Arduino just for that is a waste. Please suggest.
