I have read couple of datasheet of devices which uses SENT protocol. They define the output between 193 and 3896. The unit is LSB. I think that this does not mean least significant bit?
\$\begingroup\$ Why do you think that? \$\endgroup\$ – Andy aka Jun 4 '18 at 11:21
\$\begingroup\$ because LSB is not an unit? I don't know \$\endgroup\$ – Kono Jun 4 '18 at 12:19
It does in fact mean LSB or, alternatively, the measurement amount corresponding to 1 LSB. The specs you're looking at are measurement ranges. The numbers given are the highest and lowest readings you can expect. Note that they're 12-bit readings, meaning they have a potential (positive) range of 0 to 4095. 4095 what? Depends how it's calibrated, but to skirt that quagmire, they call it a LSB and spec those ranges accordingly. It's kind of like using "percent of full scale" as a unit, but the fact that it's already digitized makes LSB a natural unit.
\$\begingroup\$ I did not understand your explanation. LSB means least significant bit or byte. Yes indeed, the 12-bit data represents a value between 0 and 4095. \$\endgroup\$ – Kono Jun 5 '18 at 16:05
\$\begingroup\$ Example: 2500 LSB means 2500 least siginicant bit or byte. That does not make sense.. \$\endgroup\$ – Kono Jun 5 '18 at 16:05
3\$\begingroup\$ 2500 LSB is interpreted as a numeric value of 2500 times the amount and units represented by 1 LSB. For example, if you have a range of 0-3.3V using 12 bits, 1 LSB means 3.3v/4096, or 0.0008057V. \$\endgroup\$ – Cristobol Polychronopolis Jun 5 '18 at 16:26
At one company we've used internal terms "A/D count" or "A/D tick" for this. The meaning was the incremental amount of physical value1 which corresponds2 to an increment of 1
in the digital value3.
1 Usually voltage or current, but could be other physical values too.
2 The correspondence is usually linear.
3 From 0xA2 to 0xA3, for example.
Why use arbitrary units such as LSB, A/D counts, ticks instead of using physical units of measurement? I can see two reasons.
- The exact relationship isn't always known.
For example, a relationship between input voltage and the A/D reading depends on the reference voltage. The authors of the datasheet at the time of writing can't know what the reference voltage will be, and it may also vary dynamically. - The A/D values are always integer, and it often makes sense to stay with integer calculations. In some embedded controllers, for example, floating point math isn't practical.
I also use "epoch" as a unit of time. A sampled system usually has a refresh rate, and one epoch is the refresh period. Why not use normal units of time? The period may be an odd-looking number when expressed in engineering units of time (how about 17.39ms). More importantly, I may decide to change the refresh period during the project.
Sometimes I end up with [ticks/epoch]
as a unit of measurement. Why not.
