I have some trouble with understanding the following IC and its SSC interface:
It is stated in the datasheet, that the SSC interface is SPI compatible, exactly what I need. Now first of all, how should I connect this SSC interface to an SPI interface? Can I do it as follows:
SSC -> SPI
CSQ -> SS
SCK -> SCK
DATA -> MOSI/MISO shorted together
Second, I'm not even sure if I can read out the absolute angular position of this sensor over the SSC interface alone, also I cannot find any list with all the available registers I can read/write to. I think this normally should be included in the datasheet. On the website of Infenion are no more datasheets available, that specifies this SSC registers. Anyone an Idea where this could be hidden?
