Here's the schematic for my car:
The head unit is referenced to car's chassis. My amplifier and DSP are in the trunk. The DSP has an isolated DC/DC converter. And the amplifier internally connects signal ground to the chassis. This form a massive ground loop from the head unit through the RCA cables through the ground connection in the amplifier through the car's body back to the head unit. This has been a source of whine and noise.
I know about the ground loop isolator transformers, but those usually introduce a huge amount of distortion and dirty up the sound.
Other than a transformer in the way of the signal, what are some ways I can break this ground loop?
I am designing the DSP, so I have full control over how it manages the ground. It consists of an ADC daughter board, a DSP board, and 2 DAC boards. All the ground connections in the DSP are connected together, but I have the ability to change that. I thought about opto-coupling the i2s signal coming out of ADC, but I'm not sure if that's a good way.
Grounding
All grounds in a car or system should have a common return point, such as a bolt that is chassis mounted. The battery ground is often right to the metal chassis close by. It is good but not ideal so some noise can exist. In electrical panels all grounds return to the panel that sourced the power, so no ground loops possible. A ground loop is created when a device ground connects to another devices ground before it reach's a common grounding point.
Assuming all grounding is solid and very low resistance:
Alternator
The key is not ground so much as it is the power feed to your head unit and amplifier. The whine comes from your alternator and the only way I have been able to kill the whine was to insert inductors in the power feeds to the head unit (most effective and lower cost) and power amplifiers.
Filters
The head unit seldom pulls more than 5 amps so a 10 amp 1 mH inductor (often in the shape of a toroid) often took care of the problem, because noise in the head unit is fed back to the amplifiers that faithfully amplify the noise as well as your music.
If some residual noise remains install 1 mH inductors to the power feeds (from the battery) to the amplifiers, rated for twice the current the amplifier is rated.
Battery
The battery is assumed to be a good noise filter, but if you test it for AC noise or use a oscilloscope on the terminals while the engine is running you may find several volts of noise that match the alternator whine. Filter capacitors are already in your head unit and amplifiers but like the battery they cannot filter out a strong alternator whine. The inductors complete the filter network by chocking off the whine about 99% in most cases.
Warnings
You could put an inductor at the alternator output but car manufactures warn that if it is too small (current rating) it will not handle the current passing through it and saturate, as in not filter out anything. Any inductor/power choke should be rated for twice the current expected to pass through it.
They also warn of inductors of low value that may actually resonate with the alternator whine and cause back-emf into the alternator, possibly damaging the alternator. Safer to install each inductor at its point of use or off the battery power tap (after the fuse) for the device.
  • \$\begingroup\$ Thanks. I didn't think a series choke in the way of power to the head unit might solve the alternator noise. I'll try that sometime soon. \$\endgroup\$
    – darksky
    Sep 30, 2018 at 23:22
    \$\begingroup\$ You want to create LOCAL BATTERIES for the "whine frequencies". That means a 2-element Low Pass Filter. A series inductor and a shunt capacitor are the method. You may need to provide some dampening; A series value would be Sqrt(L / C). \$\endgroup\$ Oct 1, 2018 at 5:02
  • \$\begingroup\$ @analogsystemsrf. With all due respect most of the time an inductor in series with the head unit power got rid of the whine completely. Local Batteries and Supercaps were for systems with 1,000 watts of power-or more. To a certain point very heavy gauge wire was good enough. For the amps it was not so much about whine as it was power starvation from skinny power feeds. \$\endgroup\$
    – user105652
    Oct 1, 2018 at 5:22
  • \$\begingroup\$ @analogsystemsrf. There are situations where stupendous amount of power are needed because there is 5,000 watts of power in the trunk. A battery spliter, extra large alternator/multiple alternators, deep cycle batteries and supercaps packed the trunk, which was usually an older car with giant trunks. The only place we could put a RFC filter was the head unit, which usually fixed any whine problem. \$\endgroup\$
    – user105652
    Oct 1, 2018 at 21:15
  • \$\begingroup\$ @darksky Have you solved this issue? What ended up being the fix? \$\endgroup\$
    – Taudris
    Nov 4, 2018 at 14:40
