I would like to pass the output of an LT1413CN8 op-amp through a 2-pin red/green LED (looks white when off) and back to it's inverted input.
In Multisim, there is a red/green LED option but that is a 3-pin configuration. If I drag and drop a green LED and red LED from the component menu, wire them up tail to head, and transfer the design to Ultiboard, 2 separate LEDs and their footprints appear (which is expected.)
Is there anyway to build a custom component made up of those 2 LEDs, but with only 2 pins and 1 footprint?
Or, is there a component that I am not seeing in the component menu that solves this issue?
Or, is there a recently-updated library with this part? I am using Multisim 14.1
Thank you.
