This circuit shows the "current channel" of an energy meter.
IA_IN are the two inputs for a shunt (typically 250 uOhms) while TP1 is the connection to the energy measurement IC, which uses the 3.3 V supply voltage (V3P3) as a reference.
The input uses ferrite beads as a form of filter for the incoming AC signal. I want to know what the effect of saturation will be on the ferrite bead inductors at the input.
