I have the following two port network:
for which the Y matrix elements are:
  • \$y11(s): (2+3s)\$
  • \$y12(s): -1\$
  • \$y21(s): -1\$
  • \$y22(s): 1.5\$
I need to get the value of \$ZL\$ in order for the transfer function of the circuit to corresopnd to the following Bode plot:
From the two port network: Based on the equations of the network,
and the fact that \$V_2 = -I_2*Z_L\$, writing the following equations system: enter image description here
I get the transfer function \$H(s)=\frac{2*Z_L}{2+3*Z_L}\$
On the other hand, to find the Transfer function of the given Bode, I proposed:
  • num. of decades between two frequencies: $$log\frac{\omega_x}{10} = \frac{4}{20} \implies \omega_x = 10^\frac{4}{20}$$
  • In \$\omega_0\$ there is a single pole.
  • In \$\omega_x\$ theres a single zero.
Therefore: \$H(s)=k\frac{(\frac{s}{\omega_x} + 1)}{\frac{s}{10} + 1}\$
Where \$k=0.5\$
With all that, I get the following value for \$Z_L\$: enter image description here
which has absurd numbers, and therefore I suspect I'm doing something wrong, although I'm not seeing where.
Thanks in advance for any help you may give.
Turns out the proposed solution is ok overall, although there may be some errors in the numbers.
Just posting for future visitors.
