I am working with a four pin MOSFET(C3M0030090K). You can find the datasheet here. The gate driver which I am using is ACPL 337J (datasheet here). The mosfets are in one leg configuration like this:
One_leg_configuration.
Schematic:-
sch
I am getting the output at load resistance output.
However, I am also getting a similar pulse at gate of M1(The blue one is for gate and the black one is for load resistance.)
plots
(How should I attach the schematic and library files?(via google drive or mediafire or what?))
Please suggest any edits in the circuit.
    \$\begingroup\$ Please post the schematic in your question. We shouldn't have to download a ZIP file (risky) and unpack it just to understand your question. Make it easy for those you are asking to help you. \$\endgroup\$
    – Transistor
    Commented Jul 1, 2019 at 8:42
  • \$\begingroup\$ @Transistor I understand your concern. Since the schematic is large(and messy), I will upload some pics making it easy for you to understand. \$\endgroup\$
    – mANmAN01
    Commented Jul 1, 2019 at 11:11
    \$\begingroup\$ There is no detailed description of the problem \$\endgroup\$
    – Daniel K
    Commented Jul 1, 2019 at 11:33
  • \$\begingroup\$ @Transistor please suggest some edits in the circuit. Also if I want to share the schematic and library files, how can I share them? \$\endgroup\$
    – mANmAN01
    Commented Sep 1, 2019 at 7:13
