How can I interface with a microcontroller to detect presence of a 48 V supply with a source impedance of 10 kΩ without pulling down the voltage by more than 0.1 V?
I need to step down the output voltage (48V) at the drain of the IRFZ44N power MOSFET to within 5V so that it can be read by an Arduino without loading and causing the voltage to drop below 48V.
The MOSFET is acting as a switch. In the end I need to be able to tell if the switch is on or off based on the output at the drain terminal of the mosfet. How do I go about this?
