Above is the circuit diagram of my power supply. It converts input 12V DC into 5V DC and then 3.3V DC with linear regulator. I have highlighted it in red color in the block diagram.
So current situation is, whatever noise is there on 12V input voltage shows up on 5V and 3.3V. how do I filter this? How do I improve my design to get clean 5V and 3.3V even with a noisy 12V input.
If I use clean power supply 12v, I am getting best results. But i can't give 12V clean power supply to everyone. Customers can pick up any noisy power supply and it should work with my design.
Below I am attaching two waveforms , Yellow is 12V , Blue is 5V and Pink is 3.3V.
Zoomed in view
If you look at the waveforms, the noise appearing on 12V is carried on to the 3.3V. I was assuming LDO will at least attenuate it more but, it is very high. On the PCB the ground is properly stitched with multiple vias from top to bottom.
How do I get rid of this, what do I have to change or add in my design to improve it?
Note: Input 12V Dc power supply used is a 220V AC to 12V DC adapter.
