The task says:
Determine the value of resistance \$ R\$ so that true power of loads is maximum (biggest possible).
Picture of a circuit that came with task:
I solved it this way:
I know that \$ P = I^2 * R_{real} \$ and as \$ I = \frac{U}{\sqrt{(R + 3)^2 + 4^2}} \$ so \$ P = \frac{U^2*(R + 3)}{(R + 3)^2 + 4^2}\$, when I derived that, I get \$ (3+R)^2 + 4 - 2(3+R)^2 = 0 => (3 + R)^2 - 4 = 0 => 9 + 6R + R^2 - 4 = 0 \$ which gives me \$ R_1 = -5, R_2 = -1\$. The answer that I should've got is R = 5, I don't know what I've did wrong.
  • \$\begingroup\$ Not "derive", "differentiate". I get R = +1 for maximum (total) power in 3Ω and R. \$\endgroup\$ Jul 29 '19 at 19:49
If the objective is to maximize the power dissipated on the load \$R\$. Use,
\$P_R = \frac{U^2 \cdot R}{(R + 3)^2 + 4^2} = \frac{U^2 \cdot R}{ R^2+6R+9+16} = \frac{U^2}{ R+6+25/R}\$
Then, differentiate the expression to find its maximum, that is, when \$R+6+25/R\$ reaches its minimum.
If you are actually looking for maximizing the power dissipated on both resistors, \$R\$ and \$ 3 \Omega \$, use,
\$P_{total} = \frac{U^2 \cdot (R+3)}{(R + 3)^2 + 4^2} = \frac{U^2}{\frac{(R + 3)^2 + 16}{R+3}} = \frac{U^2}{R + 3 + \frac{16}{R+3}}\$
Then, find when \$R + 3 + \frac{16}{R+3}\$ is at its smallest value.
  • \$\begingroup\$ Just as a note to the OP: Take the derivative and set that equal to zero, in order to find a maximum or minimum. (It's your expectation that you'll find a maximum, of course.) \$\endgroup\$
    – jonk
    Jul 29 '19 at 19:34
Well, first of all we can write the input impedance as follows:
$$\underline{\text{Z}}_{\space\text{in}}=3+\text{R}+4\text{j}\tag1$$
The input current is given by:
$$\underline{\text{I}}_{\space\text{in}}=\frac{\hat{\text{V}}\cdot\exp\left(\phi\cdot\text{j}\right)}{3+\text{R}+4\text{j}}\tag2$$
The real power of the load is given by:
$$\text{P}_\text{load}=\text{P}_\text{R}=\text{V}_{\text{R/rms}}\cdot\text{I}_{\text{R/rms}}\cdot\cos\left(\varphi_\text{R}\right)=\text{R}\cdot\text{I}_{\text{R/rms}}^2\cdot\cos\left(\varphi_\text{R}\right)=$$ $$\text{R}\cdot\left(\frac{1}{\sqrt{2}}\cdot\left|\frac{\hat{\text{V}}\cdot\exp\left(\phi\cdot\text{j}\right)}{3+\text{R}+4\text{j}}\right|\right)^2\cdot1=\frac{\text{R}}{2}\cdot\left(\frac{\hat{\text{V}}}{\sqrt{\left(3+\text{R}\right)^2+4^2}}\right)^2=$$ $$\frac{\text{R}}{2}\cdot\frac{\hat{\text{V}}^2}{\left(3+\text{R}\right)^2+4^2}=\frac{\hat{\text{V}}^2}{2}\cdot\frac{\text{R}}{\left(3+\text{R}\right)^2+16}\tag3$$
Now, solve:
$$\frac{\partial\text{P}_\text{load}}{\partial\text{R}}=0\space\Longrightarrow\space\text{R}=5\tag4$$
And the real power of the load is there equal to:
$$\hat{\text{P}}_\text{load}=\frac{\hat{\text{V}}^2}{2}\cdot\frac{5}{\left(3+5\right)^2+16}=\frac{\hat{\text{V}}^2}{32}\tag5$$
