My goal is to create a circuit that will take in a 9V DC battery as input and produce a high steady +1500V DC signal. I don't need high current at all. 1 microamp of current will do. The scheme goes like this: I use an astable multivibrator to generate a square wave.
I replace the speaker with a transformer to step up the voltage (and step down the current). I hook up a rectifier to make the now high voltage DC alternating signal to a steady straight +1500V DC signal. Is this the proper way to go about this problem?
