So I am working on the following circuit:
I have already worked my initial conditions and the next step is to perform analysis of the charged up circuit. My charged circuit is shown below:
The charged circuit now has 4 sources. I am confused as to how I can go about analyzing the charged circuit. For some clarity, the dependent current source is 0.9vd and the dependent voltage source is 2it.
\$\begingroup\$ Wouldn't now be a good time to use Kirchoff's current law and sum up all the voltage sources around the loops in the first example? \$\endgroup\$– Voltage Spike ♦Commented Oct 11, 2019 at 18:44
\$\begingroup\$ Also, you have shown some dependent sources with no dependencies \$\endgroup\$– Voltage Spike ♦Commented Oct 11, 2019 at 18:45
\$\begingroup\$ @VoltageSpike I have summed the voltages in the first part already. As I have mentioned, I have already done analysis of the circuit with no energy stored in it. \$\endgroup\$– AugieJavax98Commented Oct 11, 2019 at 19:10
\$\begingroup\$ Can you show that? \$\endgroup\$– Voltage Spike ♦Commented Oct 11, 2019 at 19:17
Add a comment
