I am reading some answers related to my questions based on control loop stability of SMPS.
I came across this question.
The accepted answer states:
A switch mode power supply is essentially a sampled-data system, therefore the theoretical maximum bandwidth is one half the switching frequency. Practically the phase and transport lag there make it impossible to close the loop there, so 1/5 to 1/10th the switching frequency is a good rule of thumb.
I want to understand this answer in a little more simpler way with clearer terms electrically.
Can someone please break this answer down into simpler terms for my understanding? Would be really helpful.
A switch mode supply only updates the output (switch turn on / turn off / duty cycle) once per clock.
As the clock has two edges, but we only update on one of those edges, the maximum output update rate (and therefore bandwidth) is therefore one half of the switching frequency (two updates for a complete cycle requires two control clock cycles).
It is the fact that we update the output based on a clock (not continuously) that makes this a sampled data system.
As noted in the earlier answer, this is not a practical bandwidth for a number of reasons including phase and gain margin. Another issue is switch noise feedthrough (which can be difficult to remove).
A more typical loop crossover frequency is 1/5 of the switching frequency or lower.
A sampled data system is one in which the data are sampled at discrete intervals, rather than being continuous.
One continuous system is an analog filter (made up of linear components and perhaps amplifiers) and therefore the output represents the input as modified by the circuit at all times (ignoring the time it takes for the signal to pass through the filter).
In a sampled data system we only know what the input is at a set of given instants in time and we do not know what the input is between those points (this is why we filter the input so only a known band of frequencies is actually present at the input such as at the input to an ADC).
A switch mode power supply is analogous to an ADC in that the output (from the feedback loop) is measured only at specific points in time and therefore we ensure that the filtering limits the bandwidth of that signal.
There are internal components that help form the filter so here is the illustration from the LTC1735 (a high performance SMPS controller although a little old); the details of the analog parts of the loop are documented in AN76.
LTC1735 Equivalent circuit
There are external components here (which is helpful as they form part of the overall loop).
Even though the filters the error amplifier and the output filter (from the output capacitor) are analog, the decision of what to do can only be taken at the rising edge of the clock regardless of what happened between those clocks.
As we want to get the best overall response, we limit the loop bandwidth so that the samples are taken much faster than the loop can actually change (the same as we do with any ADC).
As with any ADC, there is a nyquist limit of < Fsample / 2 but that is still a relatively high frequency; to get the best overall response we trade off some of that potential loop frequency response for better loop information (the sample rate is much higher than the bandwidth of the sampled signal).
So a sampled data system is one (such as an ADC) only measures the actual input at discrete points in time rather than continuously.
  • \$\begingroup\$ Thank you for the answer. I understood till "Sampled data system". Could you please explain the bandwidth and the crossover frequency with some examples values please. \$\endgroup\$
    – user220456
    Commented Nov 20, 2019 at 12:37
    \$\begingroup\$ I will update the answer after I get some (paid) work done. \$\endgroup\$ Commented Nov 20, 2019 at 12:48
  • \$\begingroup\$ Ok thank you. Would request you to please help with simple terms regarding the switching and crossover frequency. Would help if you provide an example with numbers or analogy if possible. That might really help me a lot \$\endgroup\$
    – user220456
    Commented Nov 20, 2019 at 14:18
  • \$\begingroup\$ Hi @Peter Smith. Could you please help \$\endgroup\$
    – user220456
    Commented Nov 20, 2019 at 17:32
  • \$\begingroup\$ Can anyone else provide an answer. \$\endgroup\$
    – user220456
    Commented Nov 21, 2019 at 3:06
