In the image, three cells are arranged in a circuit. But the cell in the centre is installed such that the positive terminal is connected to the positive terminal of one cell and the negative terminal is connected to the negative terminal of the other cell.
What does this mean for the total EMF and resistance of the cells?
I speculate that the total EMF and resistance will be calculated as though the centre cell were connected in parallel to the other two. Assuming each cell has an EMF of 1.5 V and constant internal resistance of 2 ohms, this would give a total resistance of 4/3 ohms.
As for the equivalent EMF, I speculate the EMF for the centre cell would be -1.5 V and then the total EMF would be +1.5 V. Is this calculation correct?
    \$\begingroup\$ "I speculate that the total EMF and resistance will be calculated as though the centre cell were connected in parallel to the other two." - What leads you to that speculation? The total EMF is just KVL, so that part is correct. Can you find the Thevenin equivalent from the load's viewpoint? You could use superposition if it's easier for you. \$\endgroup\$
    – John D
    Commented Apr 18, 2020 at 17:38
What you have here is just a series connection of batteries, with one in the middle being connected with reverse polarity. To find the equivalent voltage you’d add the voltages according to Kirchhoff voltage law. The result is (from left to right) =1.5V -1.5V + 1.5V =1.5V . Also since they are in series there internal resistances would add and give a total resistance of 6 ohms.
