I have this component salvaged. I think it's very generic, but I cannot find it.
Properties:
  • Dimensions: SMT 1206 length size, although the width is wider
  • Logo: General Semi (now Vishay I think)
  • Texts: Line 1: LP, Line 2: 3C
  • One connection at each end
  • PCB: Unknown
I would like to know what this is, as I cannot find any datasheet or identification.
    \$\begingroup\$ The prominent bar on one end suggests teh cathode end of a diode. This page s-manuals.com/smd/lp suggests there are TVS diodes marked "LP", one of them by Vishay. Take a look at the datasheet there and see if it might eb a match (DO-214 etc) \$\endgroup\$
    – user16324
    Commented May 18, 2020 at 19:21
    \$\begingroup\$ Take a high value resistance, like 100k, in series with it. Apply 0-32vDC and measure voltage across the device. It will likely stop at some voltage, the clamping voltage. \$\endgroup\$
    – rdtsc
    Commented May 18, 2020 at 19:32
  • \$\begingroup\$ @BrianDrummond DO-214 seems SMB, and mine is more like SMA, but your datasheet is closer than what I could find. \$\endgroup\$ Commented May 18, 2020 at 19:34
  • \$\begingroup\$ @rdtsc ... I will do (my power supply can only go until 30 V). ... Update: I will do, but not now, as I need to solder it to something (I have only two hands I cannot create that 'circuit' including holding the multimeter etc. \$\endgroup\$ Commented May 18, 2020 at 19:35
    \$\begingroup\$ Note do not test tantalum capacitors this way. Doing so could destroy them. We're sure this is a TVS though. \$\endgroup\$
    – rdtsc
    Commented May 18, 2020 at 19:46
According to this, 3C would be the date code. LP is the type code.
According to this, LP is an SMBJ16A unidirectional Tranzorb TVS rated for 16 volts.
  • \$\begingroup\$ Thanks ... it seemed too small for SMB (but I don't have any reference). 16V could be useful too. \$\endgroup\$ Commented May 18, 2020 at 21:34
