Maybe the title could be better chosen.
Hello,
I have a 33V 0.8A constant voltage led driver (see picture below, the item no. is GL-1201C-8 if that can help) which no longer works. I searched online but can't find it for an acceptable price.
I understood the difference between a constant current driver and a constant voltage driver but I can't find out if I can use a driver with slightly different specs like this one (summary: output 36 W, 36 V DC, 1 A)
Can you help me on that?
And the second question is can I use a constant current driver instead of a constant voltage driver? I think I can't in this case, is that correct?
The picture is here.
