I have quite a quite long outdoor FTP Cat 5e Ethernet cable (just shorter than 90 meters) that will be used to connect 2 buildings, buried 1 meter underground. As I understand, for a proper operation and reliability it has to be properly terminated, since this is a shielded cable, and since it is laid outdoors where it may be exposed to overvoltages and voltage surges from lightning strikes. I have read a few similar questions, but none has quite specific answers, and have consulted electrical code book of my country, which suggests that underground cable runs don't need overvoltage protection, but it is referring to power lines, and does not take signal lines into consideration.
So, with that in mind I came up with a few schemes, and would like to know if my understanding and usage of them is correct:
Ethernet run variants
  1. Ethernet cable is terminated with regular unshielded connectors. As I understand, this is the worst case, as shielded Ethernet cable has to be terminated with shielded connectors. If it is not terminated, the shielding will pick up EMI from ground and from wire lines and decrease the performance.
  2. Ethernet cable is terminated with shielded connectors, that connect to switches chassis, but since switches themselves are not grounded, it eliminates the possibility of ground loop, while aslo increasing performance, but it will not protect from lightning strikes.
  3. Ethernet cable is terminated with shielded connectors on both ends, that are plugged into grounded surge protectors. As I understand, in this way the shielding is properly terminated and will protect the signal from interference and increase performance, it will also protect the equipment from surges, while also eliminating the ground loop, as in this case the current flows through the ground only in case of reaching breakdown voltage of protective equipment.
  4. The same as 3, but the cable used to connect from Ethernet surge protector to switch is regular unshielded UTP, as there is no need for shielding.
As I understand, 3 and 4 are the proper way to connect outdoor Ethernet cable to the equipment. Am I correct?
Other connections that are, as I understand, are even worse, is grounding both switches (will result in ground loop), or terminating shielded cable with shielded connector only on one side (will make EMI and overvoltage worse).
  • \$\begingroup\$ Usually the shield would be directly connected to earth/ground on one end only, to eliminate the ground loop. If there is ever an issue with the actual grounding, the least thing you want is to have grounding only via Cat.5 shield, so that any fault current would flow via it. \$\endgroup\$
    – Justme
    Aug 12, 2020 at 21:03
  • \$\begingroup\$ You can buy new 10gbit SFP+ fiber transceivers for less than 20 usd new, or less than 10 usd second hand. Rather then buy and ground a lot of shielded cable, I would strongly consider using fiber which avoids this issue entirely. It may even be cheaper than what you are considering. \$\endgroup\$ Aug 13, 2020 at 1:38
Ethernet has isolation transformers on each end (for the inside conductors), because of this is cuts back on noise and ground loops, any common mode current is canceled out by the transformer. The isolation provided by the transformer also offers some protection.
It is wise to shield ethernet in outdoor applications, a lightning strike can generate 1000's of V/m.
As for the shield, it could be terminated on one or both ends, the shield should not extend to indoor equipment from the lightning suppressors. The suppressors shouldn't be conductive from shield to shield (and from the pic it looks like it could be via the chassis.)
I would say 4 is the best option.
Instead of running cat 5 you could also avoid all problems by running fiber. I know of multi building installations on hills that run fiber, because fiber is not conductive or susceptible to EMI (or lightning).
Grounding doesn't really matter with the ethernet data or power lines (8 conductors inside) because of the isolation, and shielding doesn't matter in most cases (except I would use a shield if the cable could be affect by EMI or lightning).
The shield should not extend to a device because this could be a conduit for very large currents in the event a lightning strike induced a large current on the shield.
  • \$\begingroup\$ Thank you, that is what I thought would be the answer. The trouble of running fiber is that you actually need to either have equipment to terminate it, or hire someone with right equipment to terminate it :) \$\endgroup\$
    – Jzuken
    Aug 12, 2020 at 21:08
  • \$\begingroup\$ You can buy "pre-terminated" fiber cables which are suitable for pulling, though you need a fairly large duct to pull it through though. \$\endgroup\$ Aug 12, 2020 at 21:59
    \$\begingroup\$ @Jzuken Looking online, 100m of terminated fiber goes for about 25 USD. Plug and play. FWIW, I have fiber polishing equipment for when I make custom fiber optic devices, but I have never actually bothered to use it for ethernet. No point unless you're trying to pull it through an extremely small conduit, which probably isn't the case if you're looking at Cat5. \$\endgroup\$ Aug 14, 2020 at 3:35
