I tried simulating two slightly different versions of the Colpitts oscillator in LTspice.
Here is the first one:
This circuit oscillates at 53.8Mhz. It is quite easy to understand how this circuit oscillates just by looking at it.
Then I tried grounding the main resonant capacitor, C4 from the collector, a commonly seen method used in self quenching super-regenerative receivers.
Initially the circuit did not oscillate, but in reality they do in the above-mentioned receivers. When I selected the option "skip initial operating point solution" from the simulation menu, the circuit fired up to life and began oscillating at 52.3Mhz.
Now, my question is how does the above version of the Colpitts oscillator work?
My thought is that there is no a visible LC resonant loop, apparently. Also, C4 easily shunts any oscillations to ground there by not startup any oscillations.
Regarding what you said about the first circuit: -
For the 2nd circuit you said this: -
Given that you know how the first one works the only thing that needs to be explained about the 2nd one is that the collector capacitor, is still connected to Vcc regarding AC signals so, there is no difference in how they work. In other words, the DC source (V1) has zero AC (and DC) impedance and C4 is still effectively in parallel with inductor L1.
  • \$\begingroup\$ Thank you. May I ask what might be the reason for different oscillating frequencies? Is it due to the junction capacitances of the transistor? Also in certain cases of relatively high source impedance, such as a weak battery, the second version won't oscillate properly, will it? \$\endgroup\$
    – User
    Commented Sep 13, 2020 at 5:05
    \$\begingroup\$ Highly likely to be a SPICE thing. If you waited a good length of time in both scenarios, they would converge I'm sure. \$\endgroup\$
    Commented Sep 13, 2020 at 9:08
    \$\begingroup\$ Did you get to the point of proving that the frequencies converged @ASWINVENU \$\endgroup\$
    Commented Oct 13, 2020 at 17:06
    \$\begingroup\$ Yes I understood that and I have accepted your answer now, I must have missed it yesterday. Apologies. \$\endgroup\$
    – User
    Commented Oct 14, 2020 at 3:15
