Does differential signalling always comes hand to hand with a negative feedback circuit?Else the 1s and 0s would be the same!because if we have ground in the inverting pin then the output voltage will be 0 regardless of the resistances.
1 Answer
No, not necessarily. The receiver might just compare if input A voltage is above or below input B voltage. So the absolute voltages are not that important, the difference is.
If you have 0V at the receiver inverting pin, and the receiver has a threshold of say 200mV, then the non-inverting pin being below 200mV is 0 and above 200mV is 1.
