I will combine 4 ac/dc converter (1000 W) by using parallel operation mode to create 4 kW unit. I will add 4 LEDs to observe converter signal health.
There are digital output including POWER ON SIGNAL, AC GOOD SIGNAL and POWER OK SIGNAL. I added related piece of datasheet. And I added a design. Can you say that whether it is true or not.
- I want to ask that can I use these digital outputs to drive directly 5V LED or do I have to use a external microcontroller (like Arduino) to determine HIGH/LOW state and drive LED by usign external microcontroller(like Arduino) digital outputs?
- And which of AC/DC converter digital outputs (POWER ON SIGNAL and POWER OK SIGNAL) should I use to determine that output DC is OK? Can you advise me a way?
