While working on compensation networks or ripple calculations, it helps to know the ESR for my output capacitors. In high voltage SMPS systems, this seems to be difficult for the following reasons:
- ESR if quoted is at 120Hz. - Commonly people will explain to use Tan(\$ \delta\$) to calculate ESR for a given frequency beyond 120Hz... See issue #2.
- Tan(\$ \delta\$) seems to not be consistent across frequency (source p. 7) So unless you are close to the often quoted 120Hz, this is not useful.
- Does Voltage bias affect ESR? I assume not, but I have not found any info supporting either yes or no.
I have made crude setups to test ESR of capacitors I am planning on using, but I would like to perform it more analytically if possible... Also depending on if ESR is affected by voltage bias, that has a huge affect on the complexity of testing ESR, since this is typically for ~400V output supplies.
Any advice or experts on the 3 points above? I'm guessing the consensus will be to just estimate and test...
Below are a datasheet for reference and an image of the plots from page 7 of the Nichicon capacitor manual I reference above.
