Background
I am designing a low noise gain section for a power amplifier. This section consists of 2 parts:
  • the input section, taking care of gain
  • a single-ended to balanced buffer with unity gain (doubling with added inverter)
After extensive simulation and tweaking I managed to get to very low simulated noise output figures of -115,1dBu (20-20kHz) for the input/gain section and -117.6dBu for the differential converter/buffer.
Known facts
  • I am aware that noise in opamp configurations can sometimes have a larger than signal gain (but I can't see how this is related to this problem, nevertheless I like to mention it).
  • I am aware that noise can be added with the rule: Total noise = SQRT(N1^2 + N2^2)
  • I am aware that the above rule is only valid if noise sources are uncorrelated (as in originated from different parts for example).
Assumptions and question
  • As far as I see it, input gain section and balanced buffer stage are uncorrelated.
  • The balanced buffer stage doubles voltage. So if I tie this to the output of the buffer stage, i should be able to add noise by adding twice the input/gain stage noise plus the balanced buffer stage.
If I do this, here are the figures:
  • gain stage simulated noise output is 1.37µVRMS (-115dBu)
  • balanced buffer stage (differential) simulated noise output is 1.02µVRMS (-117.6 dBu)
  • adding these as described leads to SQRT((2*1.37µV)^2 + 1.02µV^2) = 2.92 µVRMS (-108.5 dBu)
If I simulate both sections cascaded, however, I get a different noise output (20-20kHz integrated) of 3.16µVRMS or -107.8dBu. That's a 0.7dB difference.
Am I making some wrong assumptions, should i check some overlooked details or is this an effect of other effects that I don't understand or know about? I basically want to understand why the cascaded simulated result is different from the calculated result.
Edit
first stage circuit: enter image description here
second stage circuit: enter image description here
  • \$\begingroup\$ What's the output impedance of the 1st stage? What's the input impedance of the 2nd stage? \$\endgroup\$
    Commented Dec 21, 2020 at 15:47
  • \$\begingroup\$ If you add 2x the output stage noise (once for each leg) it comes out pretty close. Might that be what's happening? \$\endgroup\$
    – user16324
  • \$\begingroup\$ output impedance of first stage is an opamp output, so near zero, input impedance of second stage is an opamp unity buffer input, so near infinite. \$\endgroup\$
    – gommer
    Commented Dec 21, 2020 at 15:53
  • \$\begingroup\$ "I am aware that noise in opamp configurations can sometimes have a larger than signal gain (but I can't see how this is related to this problem, nevertheless I like to mention it)." Could we see your opamp configurations? \$\endgroup\$ Commented Dec 21, 2020 at 15:54
  • \$\begingroup\$ output noise of second stage is already measured across the differential output. Both when simulating independently and cascaded \$\endgroup\$
    – gommer
    Commented Dec 21, 2020 at 15:55
