I'm trying to design a guitar distortion pedal, though it is not working as expected.
The built circuit behaves differently than the simulated LTspice model.
I currently do not have access to a scope, so right now I have no idea what's going wrong.
For some reason when I use the test pedal, the only distortion comes from the op-amp (clipping at the rails), however I would like for it to clip from the diodes.
I'm not too sure what's going on. If the voltage is high enough to reach the rails, it should clip from the diodes, and this is also what happens on spice.
Any help as to why this is happening would be much appreciated.
The circuit left of "in" simulates the guitar pickup, and the last resistor simulates the amplifier (roughly.)
