I want to be able to choose whether an audio signal being fed into an amplifier is inverted or not via a TTL signal. What's the simplest, cheapest, best way to achieve this? My goal is to replace the mechanical DPDT switch in this guitar sustainer circuit with something silent, controlled electrically, and can be assembled with through hole components.
Here is what I am currently thinking. So you can invert a signal with DPDT switch pretty easily. Perhaps a DPDT solid state relay exists? I found one on digikey, but it was $170. I read I could make a DPDT switch out of an arrangement of two SPST-NO and two SPST-NC switches. SPST-NO switches are cheap, however SPST-NC switches are $20-$30. I can buy four SPST NO switches and one not gate so that I can flip the logic for two of them. Below would be the result. Here's the link to the circuit diagram: https://crcit.net/c/de4ea0a434f9430594dfb446a37e6f1b
The circuit diagram image for SPST SSRs makes them seem easy to replace with MOSFETS, but I wouldn't know which ones to use. Is this an avenue I should explore?
What I have is cheap and simple enough, but I don't know what effect it will have on the signal. I know the SSRs add 6 Ohms of resistance each, but no idea how it might end up filtering the signal. If you know a better way to do this, I am all ears!
