What is difference between normal ethernet & automotive ethernet?
If I select a Ethernet phy which is a AEC qualified is that called automotive ethernet.
Please help me to understand.
Thanks
Automotive Ethernet is a subcategory of Ethernet as specified in IEEE 802.3. It operates over a single differential pair of wires, and is specifically designed for the low radiated emissions and immunity requirements of the automotive industry. The distance which these standards operate is also much shorter than other Ethernet standards, given the size of the vehicles they are intended to be used in.
Ethernet flavors considered as Automotive include:
A new 802.3cy automotive Ethernet standard is in the works to provide connectivity greater than 10 Gbit/s.
These Ethernet standards are not only applicable to automotive, however, as they are found very useful in industrial automation, building controls, and backplane applications.
An Automotive Electronics Council (AEC) rating indicates that a specific electrical component has been qualified for use in the stringent environmental of an automobile. A component implementing one of the above mentioned Ethernet standard may not be AEC qualified for use in an automobile, although they typically are. Similarly, there are many non-Ethernet devices (such as microcontrollers, CAN transceivers, etc.) that are AEC qualified.
