I am trying to design a circuit, which will drive my home valves which is on 24V and by specifications must supply 2A ( but this is quite suspicious, and probably it is requiring much lower current, but sill I wish to make it fulfill this requirement ). I found a few circuits, but when I doublechecked them - most of them ends with an issue. So, just as a precaution I wish to ask peoples which done this eventually for guide.
  • How to drive IRF520 with ESP32 3.3V output correctly ?
    \$\begingroup\$ Is the application using the IRF520 FET as a simple on/off switch, or do you need to PWM control it? And if you need PWM at what frequency? If it's just an on/off you could use a smaller logic level controllable FET to control the gate voltage of the IRF520. Perhaps with a resistor divider on your 24V rail to maintain Vgs < 20V. \$\endgroup\$
    – gcr
    Commented May 6, 2021 at 15:41
  • \$\begingroup\$ Nope, no PWM. Just simple switching on/off the solenoid. \$\endgroup\$ Commented May 6, 2021 at 15:44
  • \$\begingroup\$ I've moved the topic here, after the practitioners in the discussion pointed me more toward the right question: electronics.stackexchange.com/questions/563848/… \$\endgroup\$ Commented May 6, 2021 at 18:06
In my experience with 24V solenoid valves, they don't need the maximum listed current. For a 2A solenoid it probably needs 1-1.5A to activate, and then ~500mA to hold open. You can design circuits which supply this.
The listed mosfet has a threshold voltage between 2 and 4 volts, so it's likely the ESP32 can't turn it on from 3.3V. You would want a smaller mosfet to drive the gate on it.
This is a really obnoxious part to design this circuit with, because the gate voltage range is above a microcontroller but it's also below 24v. I would encourage you to get a logic level mosfet if you have the option to. That way you don't need to worry about all of these gate voltage thresholds, and you could use 1 mosfet and 1 resistor.
This is the best I could come up with, it should be compatible with most garden variety p-mosfets and n-mosfets, and a handful of 10k resistors:
EDIT:
This is how it would simplify with a logic-level mosfet.
Very easy to find a new part with:
  • VDS of greater than 24V, 30 is very common
  • Current rating greater than 2A
  • low RDSon specified between 1.8-4.5V, usually means its logic level
  • VGSth max of 3.3V or less
  • low input capacitance, otherwise put a series resistor
    \$\begingroup\$ If OP is able to adjust the program on the microcontroller, couldn't they invert the output (pull output pin low to energize solenoid) and omit M5, R6 & R7? \$\endgroup\$
    – Theodore
    Commented May 6, 2021 at 17:43
    \$\begingroup\$ @Theodore I don't believe so, the pin would need to be tolerant of 24v if it's in open drain due to R5. If that was the case you could high-side switch the solenoid with M4 & R5 directly and omit everything else \$\endgroup\$
    – zozwold
    Commented May 6, 2021 at 17:50
    \$\begingroup\$ I will edit the answer to show how it simplifies if you choose a different mosfet \$\endgroup\$
    – zozwold
    Commented May 6, 2021 at 17:54
    \$\begingroup\$ @zozwold ...of course you're right... it would have to be M1 that's omitted and M4 would have to be a power PMOS high-side. \$\endgroup\$
    – Theodore
    Commented May 6, 2021 at 17:55
    \$\begingroup\$ Maybe it is the best to accept this answer, and post another question. So more peoples will benefit from both ? \$\endgroup\$ Commented May 6, 2021 at 17:55
