This was a board which taken out from speedometer. At first the speedometer was cable type and the display was in digital. I'm planning to convert the cable type speed into electronic one which consist of 3-wire because the original one had worn out on its cable housing. Looking on the board inside the speedometer itself had 4 point connected into converter circuit.
I already measured between these 4 point which relatively low voltage (1.2 V something) and in ohms there are two points were shorted, assuming it was connected.
As I planned to convert into electronic type instead cable ones, do this possible? Also what kind of component on U2 location? I'm attaching also the electric type of speedo gear that uses wire to send signal instead cable that I'm going to convert.
