I'm designing a low-voltage and low-power push-pull converter for an isolated communication interface. The output will be 5 V, 0.5 A. I would like to have an hint about snubber networks on the primary side.
The center-tapped transformer will be driven by two MOSFETs, whose gates will be controlled by an external chip at about 500 kHz.
- Should I add snubber networks (e.g. RC-series)?
- Where should those be placed (in parallel to each MOSFET or in parallel with terminals 1 - 3 of the transformer)?
The question arises because all the low-power designs I've seen and used (e.g. Texas Instruments SN6505B) show no snubber networks in their schematics, but as far as I know there is always a leakage inductance of the transformer that should be discharged by a snubber network during MOSFET opening.
