I'm using an TS12A4514 CMOS switch in order to isolate some digital lines from one device to another. Power rails are 5V & 0V (GND).
While the switch is enabled (enable input is 5V), input voltages both high and low register almost exactly the same on the output.
When the enable output is low (0V) the input is disconnected but I can see anywhere between 200mV to 600mV on the 'NO' terminal, regardless to what is connected to the 'COM' terminal. I have tried driving the enable pins with a low voltage and with an actual short to GND with a wire, saw no difference.
Currently there is nothing connected to the 'NO' terminals so they are floating in the air. The power supply comes from an NIDAQ device and so are the enable control and digital input signals.
Is there something fundamentally wrong with the circuit? Shown here below: The ICs are all decoupled with 100nF caps near them, not shown in the schematic.
