By using the following single LM324 circuit, I create amplified bipolar outputs from a 16-bit 0-3.3V DAC output as follows:
My aim is to minimize extra DC error due to the above LM324 circuit especially not to increase the DNL at the final output. Now for Vp I guess I can use a precision 3.3V voltage reference(?). But for the rest I'm not experienced enough to proceed.
How important in this case the supply/rail voltage stability? And how can we quatify the drift due to LM324?
edit for an answer:
edit:
