Assume three-phase balanced loads in Δ or Y configuration connected to three-phase AC voltage sources in a Y configuration.
Does each load in three-phase loads consume equal average power? Assume symmetry of voltage sources and loads and voltage sources being in a positive phase sequence. Does each load have the same impedance?
  • \$\begingroup\$ But the load in a 3 phase system is made of 3 single phase loads... \$\endgroup\$
    – Miss Mulan
    Commented Sep 21, 2022 at 16:04
    \$\begingroup\$ You're answering your own question; at the end you say "Does each load have the same impedance" but you further constrain the question by saying "balanced load"/"assume symmetry of...loads" \$\endgroup\$ Commented Sep 21, 2022 at 16:06
  • \$\begingroup\$ Yes. I saw a problem in a book which says three phase balanced loads which I interpreted as three equal impedances implying they consume same power . Then I saw another problem in which in three phase balanced loads, the loads consume unequal power. This seemed like a contradiction. Which is the correct way to think about three phase balanced loads? \$\endgroup\$
    – Amit M
    Commented Sep 21, 2022 at 16:16
A balanced, 3-phase load has equal impedance for each of the three individual limbs.
If the supply is balanced and the load is balanced then yes
But, you can't rule out imbalances in both that conspire in such a way to produce equal power in all three limbs.
Does each load in a three phase balanced load consume same average power which they get from three phase voltage sources?
Only when the supply is balanced.
