I have looked all over and haven't seen any questions about this topic. This may be more of a mechanical question, but none the less, the dilemma on hand is how does twisting a set of equal length wires affect the end length?
Through some side work, customers have requested a certain twist per inch in their builds. For example, some customers have requested 2 twists of wire per inch of length such that 100" of wire will have 200 twists.
What I'm trying to get an idea of is some kind of equation that can be used to calculate how long of a wire I need to cut and how many twists will be needed to achieve the desired length of wire. I'm considered factors such as AWG, insulation thickness, and how many twists per inch (ranges from 1 twist to 4 twists).
Approaching it from a geometrical standpoint the helical length equation, \$L = \sqrt{H^2+\pi^2D^2} \$. Where L is the length of wire needing to be cut, H is the desired end length, D is the diameter from each wire core center. My trouble comes now trying to figure out how to go from the helical length equation and transforming it what I need... Any suggestions on where to start?
