For my homework I need to find the small signal gains of the circuit below.
For the first part of the circuit the small signal gain is calculated with
$$A_{V1} = \frac{u_{a1}}{u_e}$$
and for all of the circuit it is calculated with:
$$A_{V2} = \frac{u_{a2}}{u_e}$$
I simulated the circuit in LTspice like this:
But when I measure the voltage at the \$u_{a1}\$ point, LTSpice, naturally, gives me a sine voltage like this:
I don't know much about this topic. Do I need to calculate the average value of this sine voltage(s) and divide it/them to \$u_e\$ to find the small signal gain(s)?
EDIT: The circuit that I simulated in LTSpice does not involve the \$R_L\$ resistor, I'm aware of it. That part of the experiment just does not involve that resistor. So there is no problem about that.
