I'm trying to implement a low-pass filter using this circuit configuration:
I first tried implementing in Cadence using an ideal op-amp:
At 1 MHz I already have around -2.29 dB, so it's working as intended.
Then U replaced that ideal op-amp with a LNA that I made:
Here's what's inside the LNA:
The frequency response doesn't make any sense. I want a response close to the ideal case.
Why does this happen?
You have a 1uF decoupling capacitor at the input of your LNA. That's why you see a bandpass behavior.
This produces a zero that, in turn, produces a high pass response. Therefore, you have made an amplifier that doesn't let DC through, so your full response has more of a bandpass behavior.
