I am using using a 5 V solar panel connected to a TP4056 to charge two 18650 batteries in series.
Has your TP4056 ever shown an output voltage in millivolts when using a multimeter?
When I check the current of the output contacts on the multimeter it seems to “trip the circuit” and then it no longer reads 7.4 V on the output contacts, it only shows around 0.4 V.
I have disconnected everything but the batteries and the result remains the same, around 0.4 V.
Everything except the charging indicator light seems to be working now that I am using a new TP4056 with a 5 V solar panel and two 18650 batteries connected through a 5 V voltage regulator to a water pump which is rated for 5 V, 3 W.
I have 3 questions:
  1. Should I just avoid checking the current with a multimeter since that appears to be the problem or is there an underlying issue at play?
  2. Is the charging indicator light now working because I am using a 5 V solar panel and I should be using a 6 V panel?
  3. Is there a problem using two batteries in series? I doesn’t make sense to me to supply 3.7 V to a 5 V pump.
  • \$\begingroup\$ Re, "When I check the current of the output contacts on the multimeter it seems to 'trip the circuit.'” Can you add a diagram that illustrates how you "checked" the current? \$\endgroup\$ Commented Apr 28, 2023 at 2:30
This is not an answer, but here's some info that might help you:
"5V panel" does not mean that the output from the panel will always be five volts. The current that a panel can produce from a given amount of light is limited, and the more current the external circuit draws from the panel, the more the voltage will drop. The voltage varies only by a few percent over most of the current range, but as the current gets close to the maximum, the voltage suddenly plummets toward zero.
The operating point where the slope of the voltage/current relationship suddenly changes is called the Maximum Power Point. That's where the panel is operating most efficiently. Smart solar battery chargers will use a "Maximum Power Point Tracking" (MPPT) algorithm that continually adjusts the battery charging rate so as to keep the panel operating at the maximum power point.
When they tell you the "voltage" of a big solar panel, they're usually telling you the voltage of the maximum power point when the panel is directly facing the sun and the sun is high in a clear, cloudless sky. That voltage is often designated as \$V_{mp}\$. I don't know if there is any reporting convention for a little panel like the one that you're using. "5V" could be \$V_{mp}\$, or it could be the open circuit voltage, \$V_{oc}\$.
The open circuit voltage sounds better in advertisements because it's around 20% higher than \$V_{mp}\$, but it's misleading because "open circuit" means no current is flowing, No power is being generated.
https://en.wikipedia.org/wiki/Maximum_power_point_tracking
https://www.victronenergy.com/blog/2020/02/20/pv-panel-output-voltage-shadow-effect/
It doesn’t make sense to me to supply 3.7 V to a 5 V pump
It might or it might not make sense. If the pump's motor is a simple, brushed DC motor, then 5V probably is the maximum allowed voltage. A brushed DC motor will spin at a speed that is approximately proportional to the applied voltage. If you apply 3.7V to a "5V" motor, then the motor will spin at around 74% of the maximum allowed speed.
On the other hand, if the pump has a fancy, brushless DC motor (a.k.a., "BLDC motor") then the motor's built-in electronic controller probably will not work at all if you don't supply the expected voltage.
  • \$\begingroup\$ Thank you for clarifying this. The motor is is a BLDC motor and does not work unless supplied the correct voltage. I'm awaiting receipt of a step up XL6009 adjustable voltage converter as well as a 6 v solar panel in case that helps. \$\endgroup\$
    – cheelo007
    Commented Apr 30, 2023 at 19:34
TP4056 is a charging chip for single lithium cell.
You say you have connected two cells in series, and the TP4056 can't charge that. Also, even if the chip would be a charger for two series batteries, a 5V supply can not be used to charge two series batteries.
You also can't check for current by poking multimeter probes to V+ and V- terminals. It shorts the terminals. Current must be measured in series.
  • \$\begingroup\$ Thank you. I am realizing these errors as I do more research. I was indeed using the multimeter incorrectly. \$\endgroup\$
    – cheelo007
    Commented Apr 30, 2023 at 19:36
