I'm using this WFI32E01PC module.
I've 2 questions from the datasheet. I'm referring the table 3-1 from page 29 of the above datasheet.
I'm not planning to use USB pins of the module. Pins 4,5 & 6. Hence, according to section 3.2.5 unused I/O pins, on page 35, I am planning to configure the pins 4,5 and 6 as output and drive low. They will not be connected and left floating. Am I right in doing so? Or should I connect some pull-down resistor on those pins after configuring them as output and driving low?
I need two SPI peripherals and 2 UART peripherals. In the table 3-1, I see I have SPI1 peripheral available. But SPI2 is not available. But I see SCK2 available in pin 43. What about the other SPI pins for the SPI2? They seem to be missing?
I also read about the PPS feature in page 217. Should I just consider the pins having the PPS feature and configure them as SPI for my second SPI peripheral in the module?
