I want to use 3 I2C peripherals connected to this WFI32E01PC. This part has 2 options. Either MCU or the 54-pin package WFI32 module. I plan to use the 54-pin module.
But on page 3 of the datasheet, Table 2, this module seems to have only 1 I2C peripheral. But I require 3. In that case, I read there is an option called bit-banging. Can it be implemented on this module to interface the remaining two i2c peripherals to the GPIO pins of this module?
Also, does this module support a standard JTAG interface or SWD interface for programming?
I checked this user guide of this WFI32 Eval board, but the debugging section on page 8, doesn't confirm that we can use a standard JTAG or SWD interface.
