I am designing a power supply with a variable current source capability. I am using this circuit for my design(just a sample). Here I have a simple 15V transformer based power supply to give the voltage at the collector. I am getting abit problems including the voltage drops due to which I decided to use mosfet instead. But as far as I have calculated mosfet is not able to give me the desired results. My load is variable means I have change the load(5ohms shown) and change the currents accordingly. But with a mosfet i am getting biasing issues. Is there any way to go for mosfets or should I work on with transistors. I have usually seen transistors working in power supplies so is the biasing of mosfet a reason for that?, mosfets being used in switching mostly. Kindly suggest me some answers.
Here the 5Vs are from a regulator. The question is just wheather mosfets should be used or not in this case...
