I am working on an Active Noise Reduction project for a headset using Codec ADAU1772 from AD. There are two inputs, one of which is feedback mic. connected to AIN0, second is INT+ (Intercom or music) connected to AIN1. I take both inputs directly to the Codec for filters and EQ. Then, the Codec drives the 50ohm speaker with LP (Left Positive, Pin 22) and LN (Left Negative, Pin 21) differentially. The complete system works with external power (V+, 5V to 28V, typically 24V). The schematic is below.
For safety reasons, during a loss of power, the headset user should not lose the intercom signal. How can I manage this situation? I need to build a secondary driving circuit to understand a power loss and drive (not differentially) the Speaker automatically when it happens. Can a relay solve it, or transistors, etc.?
INT+ signal has enough power to drive the speaker.
VCC, VCCIO = +3V3
U1 = EEPROM
U3 = Trigger
U4 = Power Converter
U2 = ADAU1772 Codec
during [an interruption] of power, the headset user should not lose the intercom signal
Whatever not lose the intercom signal means specifically, for an electric gizmo to keep working during a significant interruption of its primary supply of power, you need some backup, often battery. Uninterruptible Power Supply means mains power to same voltage&frequency more often than not. \$\endgroup\$
