I am designing a buck converter, based on a TI chip. Both the datasheet and an excellent document "Five steps to a great PCB layout for a step-down converter" show vias in the exposed pad, under the IC.
The application note states:
Starting with ground, vias are best placed directly under the IC so that the exposed thermal pad conducts its heat down into the PCB layers. This is required to achieve the IC’s best thermal performance.
And the example layout looks like:
Via-in-pad is an expensive service from most PCB manufacturers, especially at low volume. The design I hope to achieve will occasionally (but not continuously) run at the top of the converters capability at 5V / 8A (40W).
How important are these vias for thermal performance, and are there any ways to compensate for the lack of via-in-pad?
