I have built a PCB using IC 74HC245D for levelshifting 3.3v signal to 5v signal for RGB LEDs. But by mistake, I used TSSOP-20 footprint in my PCB, and while ordering parts I ordered a SOIC package so it's a mess as TSSOP IC is not easily available in India.
After a lot of searching, I got one IC that might work but I am confused that it will work with 5v or not. IC is 74LCX245MTCX datasheet says that it can tolerate up to 7V. The link for the datasheet is Here.
But when I looked more into the datasheet I found it says the max is 3.6V so now I am confused, will it work with 5v or not?
Attaching my current schematic I am using 5v as Vcc.
Anyone here might have used this IC and can share some more info or any alter part that I can use.
Thank you for the help.
