It's not a relay but a two-channel switch amplifier with isolated barrier, used in 'Intrinsic Safety' applications.
'Intrinsic Safety' is an approach to the design of equipment intended for use in areas with a flammable or explosive environment. The idea is to reduce the available energy to a level where it is too low to cause ignition. That means preventing sparks and keeping temperatures low.
In such an environment the current in electrical switches and sensors (known as 'Namur' sensors) is to be limited to 1.2 mA (On) and 2.1 mA (Off).
The symbol depicts the galvanic isolation that separates the input, output and power supply circuits.
In simple terms the switch amplifier, intended for 'Intrinsic Safety' applications, is used to transfer digital signals from a hazardous area to a safe area.
